Saltar al contenido principal
The Golf Mk5 was introduced in Europe in the autumn of 2003, reaching the UK market in early 2004. In North America, Volkswagen brought back the Rabbit nameplate when it introduced the vehicle in 2006.
Preguntas 24 Ver todo
My RPM is crazy high
Hi i just bought myself a 2007 Volkswagen Golf city 2.0 5 speed manual and well first thing i noticed was my RPM was insanely high for example i would be driving at 120km/h 75mph and my rpm would be at 4000 in fifh! Anyways i was wondering if there anything i can do to bring down my rpm or if the car is just made like that
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
Respuesta Más Útil
The 5 speed manual transmission on the Golf 5 has a pretty close gear ratio which means the rpm's are pretty high at higher speeds. What engine do you have in your car (Diesel or Petrol, how many KW?)?
Do you only have the seemingly high rpm's when accelerating or also when cruising? If you would only have the problem when accelerating then it could also be a slipping clutch.
Fue útil esta respuesta?
Puntuación 1
4000 RPM'S is not good on your engine if it was an automatic I would be concerned about it not shifting gears as a manual I wonder if your transmission is actually shifting as it should
Puntuación 0
1 comentario:
I have this issue but my car is automatic and at 80 it’s rpms are at 4000!!! Help me,
It’s a 2003 Volkswagen gls 2.0 automatic it was fine until today. I flushed all the fluid and put new stuff in. Do you think we put the wrong stuff in I asked the guy at the store and he said he was 100% sure but like I can’t afford to fix this cars transmission
- de
I own a 1999 Cabrio GLS 2.0 auto and it’s always had the high RPM’s at cruising speeds since it was new. It’s simply geared low to provide for quick acceleration. So it’s completely normal.
Puntuación 0
Añadir tu respuesta
Patrick Carrière élève estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 2,215
