Saltar al contenido principal
Guías de reparación y soporte para el controlador de juegos independiente de Nvidia lanzado el 16 de enero de 2017.
Nvidia Shield Controller (2015) touch buttons replacement?
So a while ago my 2015 1st gen Nvidia shield front touch buttons stopped working, and I thought it was a bad 12-pin cable. It turns out it's the touch buttons (nvidia button, home button, back button, and play button) that stopped working. I have searched far and wide for a replacement but haven't found anything. Can anyone direct me to where I can find one?
Thanks for responses in advance :)
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Mine also stops working but it’s a firmware issue. Recently I found out, when I cut out the power by disconnecting the battery from a 2015 controller and plugged back in everything works like a charm until I reboot or shut down the console. So I made a workaround. I drill a hole on a controller and connect a switch to the battery. It was annoying the old way now I just hit the diy switch off and on and everything works fine
Regards
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Matrucious estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 16
Todo El Tiempo: 1,766
