Saltar al contenido principal
Manuales de reparación e información para la línea de tabletas Microsoft Surface.
My charger doesn't charge.
After going down from lack of battery, my tablet won't charge. The charger Light doesn't turn on, and I need some solution that doesn't involve buying a new one or throwing everything against the wall...
Es esta una buena pregunta?
Puntuación 2
1 comentario
Just tested with a multimeter, and apparently the charger is working...
The problem must be in the battery.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
@gc05 you could check your charger with a multimeter first to make sure that it is working. If it is then you are possibly having issues with either the charging port Microsoft Surface Charging Port Replacement or the battery. If your battery is depleted or discharged below the charging threshold it will no longer accept a charge. Replace the battery and see if that works. Sustitución de la batería de Microsoft Surface
Imagen de Microsoft Surface RT Paquete de baterías
Guía
Dificultad:
Moderado
5 - 10 minutes
Imagen de Microsoft Surface RT Charging Port
Guía
Dificultad:
Moderado
15 - 30 minutes
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Gil Cancela estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 25,234
