Google Play Services will not reinstall!
Google Play Services I'll not reinstall on m table.
Help please.
I truly appreciate it!
Es esta una buena pregunta?
Help please.
I also had the same issue with my RCA tablet. I tried every troubleshooting step but nothing seemed to work until I manually downloaded the Google services update file (apk) online. Follow these exact steps and it will work for you too. First, go to settings> security> scroll down to unknown sources, tap to select the switch and turn it on. Now open this link https://google-play-services.en.uptodown... tap on the download button, when a warning pops-up tap on OK to confirm. During the download, go to settings>storage>other>download and see the progress of the download. When its finished tap on the downloaded file, then allow for it to install. It will take around 10 to 15 minutes for the installation to complete. Once google play services is finished updating, tap done. Finally, restart the tablet. Google services will now be updated and all apps should start working. I hope that helped you.
Fue útil esta respuesta?
i cant even get into my tablet I cant get past wifi network to even download anything
i have the same after i did a factory reset so i could sell the tablet
Google services has stopped install from usb stick.
Keep ack. Google error 9k ok ok ok
Copy google. Apk to usb drive.
Insert usb drive. Select yes to enable write.
In config
Storage & usb
Tree down to usb drive
Double tap install apk file
My mom has a viking 10 III tablet and she is trying to login to her tablet but it not letting her and i am out of options i need help please
I also can not get passed wifi screen how do I download Google play on a USB please before I Crack this tablet in half lol thank you in advance
I will like to have my Google play store
I can not sign into my rca tablet because my google play services has stopped fix
I have the same problem. I have read the various 'fixes' online, but the issue is I cannot get past the initial setup screen for all the 'Google Play Services" alerts that keep coming up. Left the unit on for over two hour and no progress. How do i get past this?
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 19
Todo El Tiempo: 4,119
I inadvertently dropped chrome on this tablet, trying to restore it
- de james hayes
I inadvertently dropped chrome on this tablet, trying to restore it.but not on this tablet my other RCA 8 inch WI FI AND SHARE ARE ON
- de james hayes
