Saltar al contenido principal
Modelo A1502 / 2.6 GHz (Turbo Boost hasta 3.1 GHz) o 2.8 GHz (Turbo Boost hasta 3.3 GHz) procesador Intel Core i7 de doble núcleo con 4 MB de caché L3 compartida.
Preguntas 494 Ver todo
Keyboard not working only works for 5 sec at boot up
Keyboard not working in MacBook Pro 13” mid 2014.
All reset keys works at when powering up.
Also when force turn off (shift+control+option) it works. It turns off the machine.
I Did the SMC, PRAM, and NVRAM.
Also did the Hardware Test (option+D). No issues shows.
Keyboard works for 5 seconds when powered up(at boot).
Setups I did.
1. Power Key presses
2. Pressed the caps lock(green light comes on) worked for 5 sec
3. Pressed the Space Bar at hardware test to connect Internet. Worked for 5 sec.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
The trackpad on this model can cause strange issues with the keyboard (if it's unplugged for example, only the power button will work). We have seen a lot of the trackpads on 2014 13" models fail in strange ways, causing intermittent issues like this.
First thing to try is a test trackpad and trackpad cable to rule out this causing the problem. Worth checking the logic board beforehand, in case there are any obvious signs of liquid damage.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Thank you
Yes, trackpad was causing a problem. My trackpad cable got broken when replacing battery. I thought keyboard will work but it didn’t. When I replace the trackpad cable everything went back to normal.
Fan not making loud noise and system is also back to its speed.
- de
Añadir tu respuesta
Mohit Patel estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 57
