usual SD card will not go in slot.Could something be blocking?
I have successfully used the card before now it only goes into the slot halfway. I do not see anything in the slot
Es esta una buena pregunta?
Try rotating the card 180 degrees and inserting it. It will only go in one way.
Fue útil esta respuesta?
I have the same issue, it's not the way the card goes in.
I got it from a pawn shop. Can't tell if there is an old card broken inside, or if the popup housing might be broken.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 435
