Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
Un lector electrónico lanzado por Amazon.com el 27 de abril de 2016. El número de modelo es SW56RW.
My Kindle Oasis fell into the water. Can you repair it?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
Solución Elegida
@goodharbor122 we can't fix it for you. We are volunteers that help others to fix their own devices. In the case of your Kindle, I recommend that you totally disassemble it using these guides Sustitución de la placa madre del Amazon Kindle Oasis 8ª Generación Then clean every part with some 90%+ isopropyl alcohol. That includes the cables, connectors etc. Use something like this guide Reparación de los daños en un iPhone debido a la entrada de líquidos to see how to clean a device. The guide was written for an iPhone but the same pretty much applies to any device. After you clean it and have it dried, replace the battery and then reassemble. Only then can you evaluate your Kindle for any other damage.
Imagen de iPhone
Guía
Dificultad:
Difícil
1 - 2 hours
Imagen de Amazon Kindle Oasis (8th Gen) placa madre
Guía
Dificultad:
Difícil
20 minutes
Fue útil esta respuesta?
Puntuación 4
you will need to take it to a local repair shop as this site is to help people, not for repair service
Puntuación 2
It happened to me because I used it in the swimming pool (underwater....) and next week started to frozen and finally didnt respond.
I put it in a dehumidifier (it can be a single sealed box with a dehumidifying tablet that you can buy for ~€2/$2) and leave it for at least 48 hours, and now It works again
(the first few minutes it may be a little slow, but then it will be fine, like the first day).
Do not do as other people say of using a hair dryer, it can even be dangerous (the back is made of aluminum, so it can hurt your hand when it is hot, like it happened to me :-( )
Good luck
Puntuación 0
1 comentario:
this post was 6 years ago
- de Compartir
Añadir tu respuesta
Loretta Ligor estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 20
Todo El Tiempo: 990
