My Acer Aspire XC-780‘s wifi not working
I have the same computer as my little brother. Just when we got the computers, i realized something weird. His computer’s wifi is running fine. But my wifi runs VERY bad. I can’t install anything, cause it stops just when the download starts, and with some wifi’s i can’t even enter a browser, which my brother can. I need help solving this, cause i can’t use my computer to anything online.
Es esta una buena pregunta?
12 comentarios
I downloaded the newest version. It did not work at all, so i uninstalled it. Do you have any other solutions?
- de Albert Frankenstien
Hi @duckydasher ,
What is the status of the WLAN adapter in Device Manager? Right click on the adapter entry and select Properties > General
What is the make and model number of the WLAN adapter as described in Device Manager?
What is the signal strength indication of your WiFi network as indicated by the OS? Don't know your desktop, but do you need antenna(e) connected for the WiFi? If you have a no - to - low signal, if possible try swapping antenna(e) with your brother's desktop.
- de jayeff
I will try that later. But i might have found a way to solve it. But i can’t acces my computer right now, so i will do it later
I’m so sorry but i’m not that much into computers, so i do not really understand what you just told me to.
Hi @duckydasher ,
Right click on the Windows start button (left side of Task bar) and click on Device Manager.
When Device Manager opens, scroll down to Network Adapters and click on the + symbol to expand the entry list.
Locate the WLAN adapter entry - should either be a Qualcomm or Intel entry.
Let's know if there is a red cross or a yellow exclamation mark against the entry
If there is no crosses or marks right click on the WLAN entry and select Properties,
Check the Device Status in the General Tab.
This is where you could have updated the driver in the Driver tab > Update driver button .
With regard to signal strength. I was hoping that your computer would show WiFi signal strength bars (1 - 5 bars - like on a mobile phone) on the right hand side of the Taskbar indicating the strength of the WiFi signal.
- de jayeff
Mostrar 7 comentarios más
