interior fan not working, needs to be replaced, how?
Es esta una buena pregunta?
@pa_pa_pa you do want to make sure that you check the fuses and the controller first. Then check the resistor block. Ultimately if it is your blower, use the attached part of the manual for the troubleshooting and the repair GC-HVAC.pdf
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 46
1 comentario
Are you sure it is dead? Have you checked all your fuses and relays, and switches?
- de sm_vulkus
