Saltar al contenido principal
La tercera generación de iPad, lanzada el 16 de marzo de 2012. Guías completas de reparación de modelos 4G y Wi-Fi. Las reparaciones requieren calor y palanca cuidadosa.
Preguntas 20 Ver todo
Tear down battery replacement
Instead of using microwave to heat pry tool are there dangers using a heat gun?
Es esta una buena pregunta?
Puntuación 1
1 comentario
Thanks to those who answered.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Hey Wayne,
There are definitely dangers in using a heat gun but it has been the industry standard for softening adhesive for part removal for years. Those dangers primarily being heating parts of the device that you do not intend to heat. If the "pry tool" you are referring to is the iFixit iOpener, then I would highly recommend using that. It is a fantastic tool for only applying heat to the areas that you intend to do so on and it has been a joy for me to use on past repairs.
Imagen de No more adhesive battles! With our iOpener, you can quickly and easily remove glued components in electronic devices whether you're a repair professional or beginner. Apply gentle, even heat to loosen the adhesive holding smartphone, tablet, and laptop case components and batteries.
Producto
iOpener
$17.99
Fue útil esta respuesta?
Puntuación 2
Respuesta Más Útil
I'm thinking you are talking about the bag that you heat in the microwave for apply heat to the glass. It';s an OK tool but slow and probably very good for a beginner. Using a heat gun takes some practice. It is very easy to over heat. On a product with an LCD-LED display, overheating and damage the display and you get white areas. I am speaking from experience because I have done it. On a MacBook Pro you can melt the clutch cover, melt the rubber gasket. I like to soften one corner then put a plastic card or guitar pick in. That puts upward pressure on the glass. The I slowly heat the glass closest to the pry oil it starts to release. I am allways moving the heat back and forth to prevent hot spots. As it comes loose I insert more picks to help hold it open and so it will not restock as it cools back down.
Puntuación 4
Añadir tu respuesta
Wayne Wishart estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 76
