Saltar al contenido principal
Guías de reparación para una gran selección de cámaras digitales y de cine Kodak.
Preguntas 229 Ver todo
lens obstruction error help
i have a problem.my camera is a kodak pixpro az251 i'm getting lens obstruction error trying to figure out howv to fix it .asking to re-start camera nothing happens.can someone help.ty in advance
Es esta una buena pregunta?
Puntuación 5
Agregar un comentario
2 Respuestas
Solución Elegida
tornadoman1955 it is entirely possible that this is caused by a stuck lens. Follow these attempts and see if you are getting somewhere. If not, it is most likely you will need a new lens assembly.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Mine is stuck out what should I do about this?
- de
@Blair B. same situation,same link just stuck on the track for the retraction. If the link does not provide a good solution for your camera, you will have to replace the lens.
- de
Respuesta Más Útil
Hi,I bought a Kodak pixpro AZ252 camera from Walmart and I put the batteries in and also a
(PNY Elite 16GB SD Card) and when I turned it on it said Lens obstruction Re-start camera and I don’t know what to do or how to can you guys help me!
Puntuación 2
1 comentario:
Mine is doing the same thing!
- de
Añadir tu respuesta
tornadoman1955 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 14
Ultimos 7 días: 130
Ultimos 30 días: 486
Todo El Tiempo: 12,770
