Why is my fan not kicking on
The cooling fan doesn't kick on when my '02 hondai sonata starts to ovr heat...what is wrong with it??
Es esta una buena pregunta?
There could be a few different things wrong here . Lets get the obvious out of the way first. Is the fan motor done . this can be checked by jumping the fan wires directly from the battery If the fan doesn run then you need to replace it ,if the fan runs then move on to the next possible solution. . Check the fan fuses and the fan relay replace if necessary If this brings no joy then check your temperature sensor . If its not working then it cant signal the fan to kick on . Hope this helps
Fue útil esta respuesta?
Great answer , I just want to add that , this car usually has 2 temp sensors , one tells the computer the temp, and the other one works the gauge, light, and fan. But this was a great answer from original post.
excellent point @trnsmisonfixer , @short3sweet to check the temp sensor use a OBDII reader with live output to see if you have a temp reading from the computers sensor as this is the sensor that will activate the fan
My fan was working fine I just actually had my starter replaced and I had to take my fan out now my fan won't work does anybody know what the problem could
Ultimas 24 horas: 7
Ultimos 7 días: 32
Ultimos 30 días: 87
Todo El Tiempo: 8,876
