Kenmore Washer Model 110.21302012 wont spin
Our Kenmore washer model 110.21302012 will not spin. I put it on Drain/Spin mode and select start. Looking at it from the bottom, the syncronous motor starts clicking for about 10 seconds or so and the the motor turns the pulley about a quarter turn and then stops. If you wait a little longer it will repeat that cycle. Although the belt should be replaced, I dont believe thats the case. I do have a video of what its doing if that would help. Any help would be appreciated. Thank you.
Es esta una buena pregunta?
1 comentario
This one is not al ways correct. However. I am the Technician, all of above ..first un..plug, then manually spin drum. By hand, now , since the washer must be on its side get the light and I serve if any oil and worst case rust is on floor, finally. Flashlights on the gears and transmissions, oil or rust is a system of a blown tranny. Stick to the facts of its older fill in the blanks.E F. Detwiler & son.
- de ef.detwiler
