Saltar al contenido principal
2.26 o 2.4 GHz / Carcasa Unibody de plástico blanco
Preguntas 645 Ver todo
Black Screen but backlight works
Title really says it all. I also get the chime when I start it up and the backlight works. It does the same with different display. I also tried switching the hard disk but nothing seems to work. Any ideas? Thank you.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Try an LCD cable. If it still has the same issue, and does the same thing with just the charger port, fan and screen plugged in, the problem will be logic board related (probably LVDS_IG_A_CLK circuit issue, usually L9080 burns out when the screen is messed with, so it sits on a black screen). What is the history of the device?
Fue útil esta respuesta?
Puntuación 1
1 comentario:
I tried switching out different screen and it did the exact same thing. So I guess it’s the logic board. Luckily they’re pretty inexpensive online. I got it for like $80 like half a year ago and it worked fine until one day this happened. Anyways thanks for the advice.
- de
Añadir tu respuesta
Leon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 132
