Saltar al contenido principal
The BLU Vivo XL was released in January 2016 as part of BLU's budget line of smartphones.
Preguntas 59 Ver todo
Is it safe to remove back cover of phone while it's on?
I Was wondering if it was safe because I was looking around the back of the phone for a while seeing where things were and trying to figure out something while the phone was still on, is there anything that could've harmed me like an ir laser that I can't notice, other then obvious chance of getting shocked.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi,
May be wrong, but the User Guide for the phone doesn't mention the it has IR capability so that should be one less worry for you. Also radiation from the WiFi and phone signal wouldn't be any stronger to cause concern just because the cover is off. You have it right next to your face when you use it normally
Chances are that you could harm the phone more than it could harm you, especially if you poked around, even just using your fingers let alone tools.
You have to consider that the systemboard has power on it at all times even if the phone is switched off, as the battery is permanently connected to the board and doesn't go through an isolating On/Off switch. The Power switch just tells it to turn on, it doesn't actually supply the power.
If you wish to work on the phone or even touch the systemboard disconnect the battery first, unless you need power for testing purposes. Even then be aware of ESD when handling sensitive electronics. Wear a wrist strap connected to earth to minimize the chances of ESD destroying a component.
Hopefully the phone is still OK because you should be.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Hey thanks for the reply I don't know if it was this phone exactly but it was some blu phone even if it did have IR tho the IR isn't always on correct ? I would assume so and some phones need an app to turn it on which this phone was brand new with no apps yet.
- de
Hi,
Yes. If phone has IR capability it is not on by default.
- de
Añadir tu respuesta
Tsubaki Yayoi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 501
