partially not working touch screen
my phone model is karbonn a81 star, i had replaced touch screen after that the top most part of the screen is not working what is the solution for this pls help me
Es esta una buena pregunta?
tvmitc could be either a bad digitizer (most likely) which would need to be replaced once more or a loose connection. Double check your work and make sure that everything is properly connected. If so, contact the vendor your bought the touchscreen from and ask for a different one. Badd parts and poor QA are not an uncommon issues.
Fue útil esta respuesta?
when i fixed firstly the home buttom was automatically working at that time the top most portion and the notification bar was working fine ,later i replaced and again when i check the topmost portion was not working and the automatically working problem was solved
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 331
