Saltar al contenido principal
El primer Altima se produjo en junio de 1992, como modelo de 1993. Todos los Altimas se construyeron en Smyrna, Tennessee, hasta junio de 2004, cuando la planta de Nissan en Canton, Mississippi, también comenzó a producir el modelo para satisfacer la alta demanda.
Preguntas 7 Ver todo
My car died at the intersection and now wont start
My car just died at intersection I turn the key and it just makes the rrrrr sound but doesnt turn over i thought might b crank shaft position sensor but no luck can u plz point me in the right direction
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
When you turn your key to the ign position, where all the lights on the dash are on but you haven't started it yet. Do you hear a buzzing noise coming from the back? If not, check your fuel pump fuse. If it is broken/blown like in this picture then pull it and replace it with a fuse of the same rating. (colour). Should be spares in the fuse box. Usually on the back of the fuse box lid will be a list of the fuses and what they do, their numbered location and their rating. E.g. 15 amp is 15A.
If you change your fuse and you turn your key on again only until all the lights are on the dash and you hear a buzzing it should start.
If not the fuse, then assume your fuel pump is dead and will need to be replaced. Sometimes you will hear the buzzing and still no go. Could be a lack of pressure issue. If you change your fuel pump always change your fuel filter, it will be old and dead by now.
Let us know how it goes.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Cassandra estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 436
