Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Versión GSM de la cuarta generación de iPad lanzada el 2 de noviembre de 2012. Número de modelo A1459 / 16, 32 o 64 GB
Display wont turn on, iTunes says its powered
Hi,
Got an iPad here that the customer said its just not powering on. I plugged it into the PC and opened 3uTools and it wasn't turned on. I charged it for more than 24 hours waiting for life but there was none. I changed the charging port and still made no difference. So I tried a new LCD whilst it showed the Apple logo (White) it went back off after it flashed about 3 times. I have since changed the battery too and It seemed to have more power. I was able to reflash the iOS thinking it could just be a bad software glitch and it seemed to have worked. I can setup the iPad as new and seemed ok.
But after the setup when the screen timeout kicks in I cannot get it to turn the display back on. iTunes and 3uTools says its turned on but there is no display. I've tried 2 new screens now and its still the same.
Any Ideas?
Es esta una buena pregunta?
Puntuación 0
2 comentarios
I have tried 2 new LCD's and still the same affect.
It just doesn't want to come off standby mode.
- de
There is nothing on to see when I shine a light on the LCD. Totally black
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Have you tried shining a bright flashlight on the "black" screen when it should be on? I am wondering if you don't have a backlight issue. It might be partially working but not capable of handling an extended on-time.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
- de
I am not talking about the LCD's but the backlight circuit on the logic board. If multiple LCD's don't work, then the problem is probably on the logic board. Have you tried shining a bright light?
- de
Añadir tu respuesta
Jaymie estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 185
