Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La cuarta generación de la tableta Surface Pro, lanzada el 26 de octubre de 2015.
What is the suggested temperature of a heat gun to remove the screen?
Hi, I'm gonna try to open my Surface Pro to upgrade the SSD from 256 to 1T.
What is the temperature I have to set the heat gun to work on the screen removal?
Es esta una buena pregunta?
Puntuación 7
1 comentario
Hey there. Would love to know how the OP went with this. I'm also thinking of upgrading my surface book 2 256gb to 1TB!
- de
Agregar un comentario
1 Respuesta
Solución Elegida
@tpcware usual temperatures for this is between 80 and 100 degrees Celsius with 80 degree Celsius being standard. To hot and your LCD will get damaged.
Fue útil esta respuesta?
Puntuación 9
6 comentarios:
Thanks for your kind reply. Should I assume you're talking about Celsius degree or Fahrenheit degree?
Because 80°F really differ from 80°C (that is 176°F)...
- de
80°C-100°C.
Make sure not to push up against the glass or it will most likely crack the screen. What I do is cut through the adhesive, maybe some very thin flexible cards will cut the adhesive well.
- de
@tpcware that's a big Duh on my part. Sorry, those temps are in Celsius.
- de
yeah if you have access to a heat pad I'd highly recommend putting the tablet face down on a heat pad that has been set 80 C as opposed to use a heat gun as if you only have two hands then one will be required to hold the heat gun while you're trying to separate the display.
- de
How hot is "too hot" ?
- de
Mostrar 1 comentario más
Añadir tu respuesta
n.carandini estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 42
Ultimos 30 días: 193
Todo El Tiempo: 40,461
