Saltar al contenido principal
El Motorola Moto Z Play (número de modelo XT1635-02, XT1635-01 y XT1635-02) es un teléfono inteligente droide que se lanzó en septiembre de 2016. El Moto Z Play se puede distinguir fácilmente por la palabra "moto" colocada en la parte superior y el botón de inicio cuadrado ubicado en la parte inferior de la parte frontal del teléfono.
No touch response after screen replacement
I replaced a screen with a cracked LCD. After replacement touch is unresponsive. During startup, I am prompted to enter my password and after a few seconds I can do so. Once started up, the screen comes on, but I can not unlock the screen. It appears to respond to touch, because the notifications change color when selected, but it does not unlock or prompt me to put in my code to unlock. Help!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
2 comentarios
Only works now if I'm touching the screen with two fingers
- de
hey did you get a solution to this? I am facing the same issue
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hey Casey!
Incompatible screen. Moto Z Play is a difficult one to find good parts for. Have to make sure the flex configuration is exactly the same as on the original or else it either doesn't work or only works with two fingers like you mentioned.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Great! I am having the exact same issue... Anything that can be done to fix the two finger operation?
When I ordered the LCD screen on eBay, the description said the part was for Moto Z Play XT1635. There was no -01, -02, -03 suffix. So I believed it would work with all of them. I have XT1632-02.
- de
Añadir tu respuesta
Casey Reynolds estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 1,198
