How do I replace the hardrive on a PowerBook G4 Aluminum 17
how do i replace the hardrive on a PowerBook G4 Aluminum 17
Es esta una buena pregunta?
For the 17in model A1139 high resolution display PowerBook G4 use this guide: PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Hard Drive Replacement
For the 17in PowerBook G4 models A1013, A1052, A1085, or A1107 use this guide: PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement
Look at the underside of your powerbook there should be a small label printed onto the aluminum which will tell you what model number you have. I hope this helps, good luck!!
Guía
Dificultad:
Moderado
25 minutes - 2 hours
Guía
Dificultad:
Moderado
30 minutes - 1 hour
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 774
1 comentario
What's you processor speed? There are five different machines that meet your description.
- de mayer
