Saltar al contenido principal
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
Preguntas 201 Ver todo
Why isn’t my phone turning on?
i didn’t do anything i just turned my phone off and then after when i tried to turn it back on it stayed off and when i put my charger in it doesn’t say it’s charging. i haven’t dropped it or anything. what should i do?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Remove Battery and then plug into charging cable. Try and power up. If this works the Battery is dead and needs to be replaced.
Fue útil esta respuesta?
Puntuación 0
unfortunately the phone will not power on without a battery in. Try replacing the battery. If that does not work you most likely have a logic board problem, which is common over time with a phone that old.
Puntuación 0
Añadir tu respuesta
urie diculous estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 60
