Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Xterra se introdujo en América del Norte en el año modelo 2000 (año calendario 1999) y se comercializó utilizando el lema Todo lo que necesita, nada que no necesite.
Temperature gauge not working and no check engine light!
I have a 2000 xterra 4wd, my temperature gauge isn't working but my check engine light has not came on. when i turn it on it stays below the cold line, it doesnt move even after 20 min of it on. its not overheating or anything, all of my other gauges are working what could it be?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario
My temperature gauge and my gas gauge has stop working as of Thursday.
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Three things. Sensor Wiring or Gauge.
Start with the easiest
Test wires
Then test Gauge
Then replace sensor.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Thanks I’ll try this out tomorrow!
- de
This is ridiculous. Is there no one out there that knows the difference between a sending unit and a sensor? Freaking Google bone headed responses. GAHH! The coolant sensor has nothing to do with the temperature gauge in your dash and its title is misleading - it is solely for your car's computer to make adjustments. It is the coolant temperature sending unit that moves the gauge in your dash. I had this same issue in my vehicle and your symptoms sound classic for a sending unit replacement. Although, I might be asking myself what caused it to go bad if I were you. I bought my vehicle this way, and I am convinced mine went bad from an overheating. Luckily, my motor is a 7.5L 460 Ford V8 - a beast that keeps on turning. Don't get me started on the rest of the vehicle though. >:-O grr... Good luck.
- de
Check the thermostat
Puntuación 0
Añadir tu respuesta
Brian estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 36
Todo El Tiempo: 7,641
