Saltar al contenido principal
Stops charging after a few minutes
Hi. My Asus Zenfone 2 Laser is not charging properly. When I plug it and the battery reaches 30%, it stops charging. I have tried charging it on a safe mode and I've also tried resetting it. Nothing has changed. I've tried restarting the phone whilst it's plugged. It does charge,l. However, after a few minutes, it stops charging again. What could be the problem? Do you have any solution for this? Thank you
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Battery related. It's either the phone is not registering the battery properly OR the battery is just failing and needs to be replaced.
If you know a shop that has a battery tester kit they can diagnose it and determine if that's the issue or not.
Otherwise, replacing the battery would be another option
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Yep, I know this is a year later, but yes, I had this same problem. I had to replace the battery to fix it. The "new" battery lasted about a year before doing the same thing. All you can get now are 3rd-party or salvaged batteries for it.
- de
(I 2x posted so the OP could see the answer as well.) Yep, I know this is a year later, but yes, I had this same problem. I had to replace the battery to fix it. The "new" battery lasted about a year before doing the same thing. All you can get now are 3rd-party or salvaged batteries for it.
Puntuación 0
Añadir tu respuesta
Christopher estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 1,905
