Saltar al contenido principal
La serie Presario CQ58 son laptops económicos, ofrece un buen valor. CPU - Intel / AMD, Memoria RAM DDR3 2/4 GB, HDD - 320/500 GB.
Why my airplane mode button wont turn off
my airplane mode button won't turn off it is orange all the time and i can't access internet. i have tried different ways to connect to wifi using usb tethering, usb wireless port but still i am not able to access internet as the button is stll orange what can i do to turn it off?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
4 Respuestas
Solución Elegida
Go to HPs website and see if there is an updated driver.
There are a few laptops with an airplane mode bug that needs a patch directly from the manufacturer.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
there are two different ways that you can turn off your PC's airplane mode
1: you can disable airplane mode in the notification panel.
2: run the troubleshooter.
3: check the services in the computer manager if it's not running then right your mouse on it then click start.
- de
Also, check for a keyboard shortcut that enables and disables airplane mode. (Like Fn + F11). Also, you can disable airplane mode in the notifications panel on the right of the screen.
Puntuación 2
I have had this issue before, but it was on a del laptop. I ran the troubleshooter, and it fixed the issue. Try going to start and searching troubleshooter, It should bring up a page to run different troubleshooting tests.
Puntuación 1
mine isnt working even after troubleshooting. it just states i need to connect ethernet courd in order for my device to work! and i dont own an ethernet, i will not be buying one either.
Puntuación 0
Añadir tu respuesta
sanelisile estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 2,690
