Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
Preguntas 4177 Ver todo
iPhone 6 only charges while on.
If the battery ever drops to 0% and turns off it cant be turned on or charged. I have to take the battery out boost it then put it in and turn it on, where it will charge just fine. Confirmed issue on multiple batteries.
Could this be Tigris or Tristar IC?
I do motherboard repair all the time so microsoldering is an option I just want 2nd and 3rd opinions before I go replacing IC's.
Thanks.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Faulty charging port?
New charger?
por
No, tried second charge port same on multiple chargers.
por
Hmm... Maybe try a battery replacement then.
por
WAIT....I see you already tried those....Hmm...A lot of people at my school have a similar issue with their chromebooks. I can ask one of the technical people there and see if they have a better answer.
por
Agregar un comentario
1 Respuesta
Tristar chip needs replacing.
If you want you can unplug battery then plug in charger, if it doesn't show apple logo then Tristar is bad.
In some extreme cases you may even need to change charger port after tristar replacement as they can go faulty at the same time.
Fue útil esta respuesta?
Calificación 0
Añadir tu respuesta
Trent Quan-Sing estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 11
Todo El Tiempo: 49
