Saltar al contenido principal
A followup to the LG V10 smartphone, similar to the LG G5, released on September 29, 2016. The LG V20 can be distinguished by the model numbers F800, H910, H918, H990 DS Dual, H990N Dual, H990T, LS997, US996, and VS995. It is available in titan, pink, or silver with 32/64 GB of storage.
Preguntas 20 Ver todo
LG V20 no gps signals
Does anyone know how to fix the LG V20 that can't pickup any GPS signals?
I tried to tighten all of the screws in the back plate, clean the contact terminal (even pushed it up a little bit) and the antenna terminal. In addition, I have tried the Aluminum trick by adding a layer of Aluminum between the antenna's terminal and the phone's contact terminal. None of these tricks fixed the issue. Also, I reset the phone, but no lucks. Any suggestions/recommendations are greatly appreciated.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Major GPS issues. High Accuracy is on.
this is only two months old. LG refuses to warranty because it is an "unlocked" phone! (what??)
Newegg won't help. I am DONE with LG. Never again. My G3 had really bad wifi.
Now really bad GPS. Also LTE cell reception is at least two bars lower than anyone around me is getting on the same network.
I liked this phone for the hi audio quality but bad reception and bad GPS is a deal breaker. Wish I knew this before I bought.
Fue útil esta respuesta?
Puntuación 0
if you bought a refurb unit likely they put the wrong bezel on the top. takes like 3 minutes to fix. I fixed mine by adding copper tape from this link went from zero satellites to 10+ instantly
https://www.reddit.com/r/lgv20/comments/...
Puntuación 0
Añadir tu respuesta
Jack estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 3,607
