Saltar al contenido principal
Spot on the display when lifting the frame
Hello,
I'm trying to replace the kindle paperwhite battery (1th gen). When I lift the frame some spots appear on the screen so I will stop. it's normal?
Update (02/01/2018)
@Darwin I took a photos of this spot. Please check pics.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
What type of spot. If it’s like a water mark that’s normal. It means the lcd and the glass/digitizer is touching. If that’s the issue you can use adhesive tape around the frame so that they do not touch each other. If the spot looks like a white spot it could be a pressure point. Check to make sure there is no screws or strange object left in there
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Plese check the update. Thanks.
- de
Añadir tu respuesta
Simone estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 95
