Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Fujifilm Finepix S4200 es una cámara digital puente de 14.0 megapíxeles lanzada por Fujifilm en 2012.
On off button sticking and stiff
My on off button seems hard to move and sticks in postioymoved to it used to just spring back by itself
Es esta una buena pregunta?
Puntuación 0
1 comentario
Tried it made slight difference button still not working properly one of the kids must of dropped it as it still doesn’t move back itself as it use too but thanks for your suggestion will probably have to take it to a repair shops
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Sounds like a button that is physically stuck, like you said, get a bottle of Isopropyl Alcohol and a Q-Tip, dip the Q-Tip in the bottle, gently swap the switch with the wet end of the Q-Tip (make sure the device is off) switch back an forth. Rinse and repeat until the switch is loose again. Hope that helped!
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Where can I purchase a new button. My button came completely off?
- de
constant problem with these cameras. even lubrication does not help
Puntuación 0
1 comentario:
I put new batteries in the camera and won't come on
- de
Añadir tu respuesta
gazza b estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 45
Todo El Tiempo: 3,138
