How to repair etch a sketch
This is an etch a sketch from the 80's. White knobs turn, but there is no drawing. Can I fix it?
Es esta una buena pregunta?
An Etch-A-Sketch is a simple machine where the knobs end up moving a string from side to side and another from top to bottom. If the strings stretch or for any reason slip, you will get the behavior that you describe. Other than opening up the unit and replacing the string, there is not much that can be done.
Dan
Fue útil esta respuesta?
This seems like the same problem: Can I fix dead areas on the screen, where lines don't appear?
Ultimas 24 horas: 3
Ultimos 7 días: 34
Ultimos 30 días: 208
Todo El Tiempo: 11,481
5 comentarios
Did any body find any answer to this problem?
- de lorriepwr
What if it’s leaking aluminum?
- de lorriepwr
I've heard of problems like this a lot so this could be a common issue with etch a sketches
- de Percy WONG
Mine just will not draw idk what is wrong with it if some one can pls help me that would be nice it is something I use to help with stress and paying attention and dont really wanna buy a new one if you can help me that would be amazing
- de Sarah Dearry
Mine stopped working the day I got it the vertical line knob stopped working -_-
- de London Miller
