Saltar al contenido principal
El BLU Vivo XL se lanzó en enero de 2016 como parte de la línea de teléfonos inteligentes económicos de BLU.
Preguntas 59 Ver todo
Unable to hear during outgoing calls
After the latest update to my BLU XL2 I am now unable to hear during outgoing calls as well as any sound with the speaker during the calls or with Google assistant. My speakers work fine when watching video. Everything is fine when I receive a call.
Es esta una buena pregunta?
Puntuación 8
7 comentarios
You are correct @Grandy. It is the Google app. When I allow microphone permissions within the app the problem persists, but as soon as I disabled permission for the app. It went away. Thanks for your help!
- de
Gabe........How did you disable permission for the microphone? Thanks in advance. Joe
- de
I have this too! I can't hear a call when calling out, but when someone obviously answers, I press the record button & I can hear. Ugh. Thank you for the feedback, I took the ok Google advice as well as the carrier service. I'll see what happens!
- de
Thank you for this...I've had this same problem after the last update. Disabled the ok Google... problem solved.
- de
I hve buy vivo y 81 one month ago, but there a hearing problem, I am not able to hear incoming as well as out going calls . Tp hear calls , I have to on loud speaker. This the problem in this phone.
- de
Mostrar 2 comentarios más
Agregar un comentario
3 Respuestas
Solución Elegida
I had this problem after the update also. I figured out it only happens while I have "Hey Google" activated. If I disable the "Hey Google" feature everything works fine.
Google account/settings/voice/voice match, and turn off Say "Ok Google" any time.
Fue útil esta respuesta?
Puntuación 8
8 comentarios:
Thanks for the feedback. I also corrected the issue by disabling microphone and phone permissions in all apps that had those specific permissions. There were only 5or 6 total. The issue has happened since but I haven't pinpointed the actual app that is causing the problem. I will update once I do. Thank you.
- de
Thanks Grandy, I can hear again. I contacted BLU and turning off "OK Google" is the remedy they're recommending as well, until a permanent solution can be found.
- de
Your welcome. Glad to be of help.
- de
Grandy, I thank you for getting me on track again. Your remedy is spot on.
- de
Thank You... I have been going crazy with this issue. I was about to toss my phone and get a new one.
- de
Mostrar 3 comentarios más
Hello, Thanks for easy answer!
Google Talk it's looks like it is a "Bug" or "Intercellular" and "google app" need to remove forever and put "Google Company" to Bring to Court for this interception to all Mobile Phones?
Puntuación 0
I have mi phone but I can't here in comming and out going calls
Puntuación 0
Añadir tu respuesta
Gabe estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 26,891
