My 88 Sierra SLX
Can I take the transmission out of my 96 Yukon and install it into my 88 Sierra SLX short wide bed
Es esta una buena pregunta?
Will,
Those XMSNs won’t swap. The ‘88 Sierra uses a THM400 and the Yukon uses a 4L60-E. Although the bolt pattern maybe the same, the wiring harness won’t match up and the XMSN won’t shift properly.
I’d find a reputable shop that can rebuild your THM400 or clear off a spot on your bench to do it yourself. XMSN rebuilds can be tricky, however it would be a great time to add in a shift kit.
Here’s a resource for the reference:
https://www.transtar1.com/transmission-l...
Good luck!
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 118
