Why is 3rd piston not reaching top dead center
i have a 98 honda prelude 2.2l vtec base model w/ stock h22a4 motor i blew a head gasket and im in the middle of replacing the head gasket i just got the head back from the machine shop and im cleaning the deck on the block and taking a look at the pistons as i rotate the crank i notice that the 3rd piston wont come to top dead center is this an issue as meaning there is another problem i took compression test to determine head gasket blew and my readings where 50 psi at cylinder 3&4 and 1&2 were stable at 150 if this info helps
Es esta una buena pregunta?
