No Audio on Note 8 after I connect to a call until I restart.
I have an unknown issue with the audio in my note 8, I have the N950F/DS model (Exynos unlocked) and I am searching for a solution to this issue where the audio will work fine ( Music, headphones, bluetooth audio etc) until I connect to a call and as soon as i connect to it I will completely lose all audio on the phone until I restart, I thought it was a software issue but I reflashed stock rom but still no luck, any ideas on the direction I may take? (No warranty as I got it from a friend abroad when he travelled)
Es esta una buena pregunta?
Look through your Bluetooth devices. Check each individual settings and see if any bluetooth device has been set to take calls.
- de S W
Bluetooth is completely off, I think its some kind of hardware issue where as soon as the audio needs to be routed for calls there is a problem somewhere and even after the call has ended and i try to adjust the volume, I will see In- call audio instead of ringer volume and there would be no sound, i have 2 note 8 devices (same model and same firmware) but one has the issue and the other does not.
- de Carbon12
