Saltar al contenido principal
2.26 o 2.4 GHz / Carcasa Unibody de plástico blanco
Preguntas 645 Ver todo
MacBook A1342 wont start, no chimes.
I had to replace the keyboard on my A1342 because it stopped working. I took the Unibody apart and replaced the keyboard (not happy that the keyboard ribbon is far enough into the connector - any tips on locating it securely would be appreciated.) Now it wont start. There is power to the logic board, Magsafe glows green, ( and orange when charging), HDD spins as does the fan, and there is output at the USB slot. I tested the power at the two power pads, The left hand pad reads 0, the right reads 3.37 V. I have seen on here that 3.4V is required to start the machine. Could this be my problem and if so how do I correct it. I am using the correct power charger for the machine (60W).
I have also tried shorting the power pads without the keyboard ribbon in place and it still doesnt turn on.
This is turning into a bit of a project for me and any assistance would be much appreciated. I am relatively new to electronics at this level but am enjoying the learning journey.
Many Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Getting that keyboard cable in completely can be troublesome. See step #14 of this guide. Be sure the lock is in the up position. Take a piece of sting electrical tape and put it on the cable nd PULL it into position the close the lock.
MacBook Unibody Model A1342 Upper Case Replacement
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Ceitho estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 71
