Saltar al contenido principal
Revisión de mediados de 2013 de la línea de consolas Xbox 360, con 4 puertos USB y conectividad Wifi interna.
Red ring fix for xbox 360 E?
When I turn on my Xbox the fan immediately goes crazy and then after 5-6 seconds the button turns red while the Xbox is not being displayed on the screen. Is there a fix for this for the Xbox 360 E?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 10
Agregar un comentario
2 Respuestas
Respuesta Más Útil
I have xbox 360 E .
if you have this problem RROD .
  1. turn off the console.
  2. Remove the HDD. clean it with air blow.HDD Socket / Console HDD Socket.
  3. put it back. and start console.
if your console not remove the issue. use 2nd step.
1 . Remove all cables from console. include HDD.
  1. Put the console for 10 to 12 Hrs.
  2. after 10 to 12 hrs. connect all cables and HDD.
  3. start console and press Syn Button + eject button for 2 /3 second.
  4. than press the power button.
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
What u mean by put the console for 10 to 12 Hrs?????
- de
How do I fix the red ring of death for the Xbox 360 E? Nothing works!
- de
Hi Erik,
Here is iFixit's RRoD Fix Kit. Hope that helped!
Xbox 360 Red Ring of Death Fix Kit
-Cooper
Imagen de Fix kit for Xbox 360 consoles with the "Red Ring of Death" (RRoD) failure. Replace, reattach, and reclamp the heat sinks on your Xbox 360. Usually fixes a RRoD Xbox—also effective as a preventative measure. Kit includes: tube of Céramique 2 thermal compound (by Arctic Silver) screw and washer hardware pack thermal pads and heatsinks spudger Xbox 360 Opening Tool small flathead driver 1/4" driver handle with large flathead screwdriver bit and T8 and T10 Torx drivers.
Producto
$29.99
Puntuación 0
Añadir tu respuesta
Erik Rodriguez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 16
Ultimos 30 días: 57
Todo El Tiempo: 18,253
