Saltar al contenido principal
Modelo M7886 / 450 MHz o 500 MHz Procesador PowerPC 7400/7410 (G4)
Why does my Cube take for ever to power on
Hi guys,
so recently I‘ve noticed that my Cube takes really long to turn on. Like minutes. Also when I put the cable into the outlet it takes a couple of minutes for the green led on the bottom to turn on. Does anybody have an idea what could cause the problem?
Also I might have to note that I live in Germany so we have 230V mains voltage, if there is any known defect in European Cubes.
Thanks for your help!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@lambda possibly running into issues with either your power brick or your DC-DC board. You do want to check the output of those with a meter and see. Use these guides Power Mac G4 Cube and teardown to check things over.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
--- estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 100
