Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2690 Ver todo
iPhone 6s shuts off at 80%
Just replaced iphone 6s battery with ifixit iphone 6s battery replacement kit and guide. I followed the instructions including draining battery and charging it fully. The iphone shuts down at about 80%. It will not turn on until it is plugged back in to a power outlet with the apple charging cable.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
3 Respuestas
Respuesta Más Útil
its possible that the battery just needs to be calibrated but after a few charging cycles and the problem is still there i would consider contacting Ifixit and letting them know and they might send a replacement battery.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
When you say that the battery just needs to be calibrated, do you mean just try to drain the battery down to at least 10% or lower then charge 100% and do this a few times. I just replaced the battery last night and only calibrated it once.
- de
Charge the battery fully and the discharge it completely. do this a few times and if the problem still persists then i would contact Ifixit for possibly a replacement battery.
- de
If recalibrating the battery does not work, try restoring the iphone as new. If you are still having problems with the phone after restore, I would try contacting iFixit and see if they will give you a replacement battery.
Puntuación 0
I have erased all contents and setting on the iPhone and restored back to factory settings. The iPhone was still shutting off and I needed to plug it back in to start it again. I checked the battery with Coconut Battery and it still read that it is functioning well and fully charged. I then tried to see if the phone would power off if I kept the screen on and started the stopwatch. It stayed on. I then realized I needed to turn off auto-lock. Settings>Display & Brightness>Auto-Lock>Never. So far this seems to work. I was so frustrated and almost opted to just buy a new iPhone, hopefully this resolves the problem for good.
Puntuación 0
Añadir tu respuesta
Anthony Serna estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,210
