Saltar al contenido principal
Modelo A1225 / principios de 2009 / 2.66, 2.93 o procesador Core 2 Duo de 3.06 GHz
What is a CR-VPH2 screwdriver bit
I'm working on the repair guide for the 24" A1225 iMac. The captive screw on the RAM access door is a Phillips screw, but strange one. It's shallow and a standard phillips does not work well. I found the correct bit in my security bit set. It's a CR-VPH2. I can't find a wiki that explains just what this is or the initials stand for and don't want to put something in a guide that I am uncertain of. I believe the last part stands for Phillips Head #2 but I don't know what the rest is for. Anybody know?
Es esta una buena pregunta?
Puntuación 2
3 comentarios
+ for another really difficult question. I have searched all over and can find no reference to that screwdriver bit. I do believe from what I find that you are correct in assuming that PH2 stands for phillips head 2. Good luck in your quest.
- de
Not sure if anyone has seen this list - http://www.toolcobber.com.au/power-tools...
- de
Hope you got the help in here https://sawreviewed.com/
- de
Agregar un comentario
4 Respuestas
Solución Elegida
CR-VPH2 refers to a tool that is made from chrome vanadium. Abbreviation of CR-V on tools makes referrence to that "Chrome Vanadium which is used for many different types of tools because when heat-treated it has excellent properties such as strength, toughness, and resistance to wear and fatigue" and you are correct that PH2 refers to Phillips Head size number 2. Good Luck with your project and I know that your project will work out much better for you since you gained this knowledge ;-)
Fue útil esta respuesta?
Puntuación 9
8 comentarios:
+ Way to go Turkey. Thanks for the answer
- de
Thank you for accepting my answer. Good Luck with your projects :)
- de
an email with your name and contact information wouldn't be out of line
- de
Nice answer +
- de
yes this is so! all the best ............. Brian
- de
Mostrar 3 comentarios más
This is CR-VPH2 which I think stands for Craftsmen V Philips #2. I think that the V refers to the length of the shaft.
I have a Craftsman screwdriver tool which uses this sort of bit. Six are held in the handle, and one in the center shaft, driving position. To change bits, one pulls out the center, active bit, and stuffed it under one of the other bits you wish to use, forcing it out of its hole so that you can put it into drive position. It is a very nice way to carry seven bits together without losing them.
The only bad thing is that it has only two Robertson (square-drive) bits, which is what I need, and they are only sizes CR-VS2 and CR-VS4. As you might have guessed, the size I most often encounter is VS3.
Puntuación 0
All I know is that I put all of my some oddly bought or came across, collection of #2 and #3 bits together. I gathered a pretty good variety of different types of screws I could get together. Sheet rock coarse thread for wood, fine thread for 25 gauge metal, cutter screws for 18 gauge steel studs and different different sizes #6,#8 and you know. Sex bolt screws, wooden and metal commercial door hardware and closers, wooden timber sills, a variety of anchors for walls, brick etc., auto trim, square head wood screws, sheet metal, AC, plumbing, electrical,………. You get the picture.
E Z Power #2 and CR-V PH2 and PH3, pretty much came out on top about, 85-90 percent of the time with Ryobi, DeWalt, Milwaukee, in that order, filling in the gaps.
Using vice grips to hold the bit and “feel” how tight the bit feels in each screw. Slippage and difficulty of drilling and pushing in, to hold the screws while being torqued up.
Experience counts, no matter how you get it, even from someone else.
Puntuación 0
1 comentario:
Also check out on YouTube, The Project Farm, he does a great job testing stuff.
- de
I do not think that PH stands for Phillips Head, but i do NOT know that for certain. My reasoning is that I have a security but set which has CR-VPH0, 1, 2 and 3, but ALSO has CR-VPZ0, 1, 2, 3. They are ALL Philips Head, but the difference is the ones with "H" have what looks like maybe a flattened point. Also, the "Z" ones have a slight "raised ridge" between the any two of the four blades of the bit. It is not much of a raised edge, but it is definitely there. (See pic for reference. Sorry if it is not very clear but Iam definitely NOT a photographer). Again, I am not certain about the label definition, but I am certain there is a difference.
Puntuación 0
1 comentario:
@alberteinsein you are not quite correct. The PH and PZ are different PH stands for Philips and PZ stands for Pozidriv. You can see on your picture that the bottom bit has additional, smaller blades between the blades that look like a Philips. According to ISO standard, the two cross-head screwdriver types are designated as PH for Phillips and PZ for Pozidriv screws.
- de
Añadir tu respuesta
mayer estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 21
Ultimos 30 días: 101
Todo El Tiempo: 22,639
