Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
amp draw bench power
so i bought a 6s on ebay described as water damaged. recieved it this morning opened it up and on the back of the board there was at least 20 components missing. the seller said it was never sent for repair and had an apple case number. has apple started to make disappearing components lol. when i plugged it into bench power its not drawing an amps but when i press power it goes to 0.07. in the process of replacing the components. would the 0.07 indicate anything in particular. @refectio
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Hmm...never trust eBay sellers to be telling the truth...at least when it comes to iPhones.
Before making any assumptions, try to identify what components are missing. For example, are they all caps on the VCC_MAIN line? If so, then someone was short hunting. You don't necessarily need to replace all of them to get the phone to boot/operate. Are the missing components on various power rails or subsystems?
Try to figure out what was wrong initially. Test all the of the PMIC output rails for shorts. If you see issues with PP_CPU/PP_GPU...you may be SOL.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
none of the caps to the left of u2000 are going to ground and im not getting anything coming from the vcc_main end of c5283_rf or c5284_rf
- de
now all the caps down that side are to ground, think iv got all off vcc_main caps on and its drawing 0.09 -0.10 now. theres caps and coils on the front side that are shorted to ground but not drawing enough to tell me which is bad, im guessing that u2000 is knackered
- de
Añadir tu respuesta
daniel estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 433
