Saltar al contenido principal
Las chaquetas de vellón ligeras maximizan el calor sin cargarte. Absorben la humedad y se secan rápidamente para manejar las actividades al aire libre más agotadoras.
Preguntas 18 Ver todo
How do I get my fleece to stop shedding?
My fleece has been washed a few times but still sheds little (pink) bits on everything. I wore it under a different coat and found pink fleece bits all over the other coat. At first I thought it would just stop after washing but sadly it didn't. If anyone has any insight I would be so grateful! Thanks! -kate
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Hi Kate,
You might not be able to stop your fleece from shedding completely, but you can definitely reduce the amount it sheds. Here are a few tips:
1) Use a lint roller.
2) Carefully and slowly use a shaving razor to remove any loose bits.
3) As soon as you notice pilling on your fleece, use this guide to tame any fleece buildup and prevent further shedding.
Hope this helps!
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
kate estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 12
Ultimos 7 días: 86
Ultimos 30 días: 371
Todo El Tiempo: 33,176
