Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lanzado el 24 de octubre de 2011 / Procesador Intel Core i7 de cuatro núcleos a 2.2, 2.4 o 2.5 GHz
Totally Unresponsive - SMC Dead?
MD322LL/A (Late 2011 MBP 8,2) running El Cap.
Was using it in the Anchorage airport. Went outside to smoke. Came back in. Laptop had turned itself off while we were outside, which seemed odd but whatever.
Used it for a few more hours, then traveled from the one airport to another, which entailed two heated bus rides along with maybe a total of an hour outside.
Got to the other airport and the thing was totally dead. It won't boot, there's no pulsing status indicator light, it won't report battery level (which was full when I left the airport) via the little button on the side, and the light on the magsafe won't turn on when attached. I've never seen a laptop so dead.
I'm thinking the temperature back-and-forth in Anchorage thrashed something, and given that the SMC controls the power button, SIL, battery management, and battery indicator light, it is my prime suspect.
I read somewhere (damned if I can find it again, though) that the SMC is powered by a battery on the logic board. And I know that cold is rough on batteries. My hope is that it's a common button cell that can be easily replaced. But I could be on the totally wrong track here.
Is there any hope of repairing this, or is it new logic board i.e. new mac time?
Edit: FWIW, I've tried SMC reset via the standard procedure for macbooks with "non-removable" batteries (shift-ctrl-option-power, as well as the older procedure (power button for 10 sec) by opening up the bottom and disconnecting the battery. No effect. Also went through the motions of a PRAM reset, just for kicks. No change.
Magsafe charger is known to be good. Main battery status is unknown, but I'd think that it could boot via magsafe power regardless.
Update: I tried disconnecting the battery, then booting on magsafe power, to check if a faulty battery was interrupting the power circuit or whatever. No change.
Tried bypassing the power button by shorting the solder pads, both with keyboard attached and detached. No change.
Es esta una buena pregunta?
Puntuación 3
4 comentarios
@mayer might be able to help.
- de
Check the MagSafe connector on the computer for debris. Often a simple cleaning can do wonders here.
- de
Surely a dirty magsafe would not prevent it from booting off of a battery I know to be full...
But yes, I clean the magsafe regularly. That is not the problem.
- de
I have the same MacBook Pro 15 late 2011. It did the same last week. No light on MagSafe, so I used another, which lighted for a day. I had a problem with starting the computer. The day after, the fan was full speed. On the Mac Fan app, it was written: no data from the sensor. I reset the SMC a few times, first, it was successful. Another day, I unplug for a while the battery, and then the Mac Safe that I replugged, glows green a little bit. So, I let it charging and the computer starts by itself after a few minutes but the battery was not plugged or discharged.
The battery had more than 1000 cycles. When I tried it on the other MacBook, It started the computer by itself just when i plugged it, the other battery didn't. When I had performed a clean up I had noticed this curious behavior a week ago. The faulty Mac's battery charged on the second computer and could run its without a charger.
It seemed to me it is SMC related.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
If the systems battery tester is showing only a few or no LED's that tells me the battery is drained. This could be caused by a few issues besides a dead battery. As you stated you disconnected it and the system still won't boot (using the power pads as well) we need to focus on the MagSafe adapter and the AC power side of the issue.
  • What is the color of the MagSafe adapters LED Amber or Green?
  • Do you have a second MagSafe unit?
Follow this Apple T/N to inspect the connection and to make sure you have the correct unit: Apple Portables: Troubleshooting MagSafe adapters
  • If that all checks out then you likely have a logic board level issue which will need someone with deeper skills and access to the needed parts.
  • If you note the systems connector is damaged then you may need to replace the MagSafe DC-In Board. Follow this IFIXIT guide: MacBook Pro 15" Unibody Late 2011 MagSafe DC-In Board Replacement I'll warn you its a bit of work.
One issue which is rare is a bad battery tester (shorted) you might want to disconnect it to make sure thats not your issue. You'll find it here in this guide on Step21 Sustitución de la placa lógica del MacBook Pro 15" Unibody finales de 2011
Imagen de MacBook Pro 15" Unibody Late 2011 placa lógica
Guía
Dificultad:
Moderado
50 minutes
Imagen de MacBook Pro 15" Unibody Late 2011 Adaptador de Corriente MagSafe DC-in
Guía
Repuesto de Adaptador de Corriente MagSafe DC-in para MacBook Pro 15" Unibody Late 2011
Dificultad:
Difícil
45 minutes
Fue útil esta respuesta?
Puntuación 2
5 comentarios:
The battery indicator on the side of the laptop shows no LEDs. Not even the single flashing one it usually shows when the battery is drained. The OS showed the battery as full no more than an hour before I found the computer to be nonresponsive. Is it possible for a battery to drain that quickly for no reason? Is there a voltage test I can do to the pins on the battery cable to see if it's got charge?
The magsafe light does not come on at all. Not even dimly. I've tried two adapters. Same result for both. I have thoroughly inspected the magsafe plug for damage/wear/stuck pins/etc. Is there a voltage test I can do to verify that the magsafe is providing the proper charge?
The magsafe port looks fine (clean and free of scorching). I also replaced the DC-In board less than 6 months ago, so it'd suck if it failed already. I could try, though. It's a cheap enough part.
I can also try disconnecting the battery tester. It's something I haven't tried, at least.
Thanks for the tips. I'll report back.
- de
Joshua - There's lots of locations to measure power. But I can't point to the locations in this forum. This is where getting a set of schematics and board view drawings are needed. Besides you need to be able to understand what they are telling you.
At this point I'm suspecting you have a shorted MOSFET which is why your battery is drained if disconnecting the battery tester doesn't alter things.
- de
Well, I finally cracked into the thing, and it's a MOSFET alright: https://imgur.com/a/TH1ZB
Part details are in the description.
I also saw this component which looks like it might be damaged as well, but to me it's less obvious. That really does look like melted plastic, though: https://imgur.com/a/fXyuE
Details, again, in the description.
At this point, I suspect water damage due to condensation that formed while walking in and out of the Alaskan cold.
I also suspect that this is way outside reasonable DIY territory...
- de
Sorry for the bad luck. Don't forget to score & accept the answer.
- de
The answer itself didn't contain the solution, but the comment pointed me toward the world of schematics and boardviews, which helped me identify components once I spotted the damage, and you ended up being right about the MOSFET. ifixit's reputation system, as far as I can tell, doesn't allow for such nuance though, so there ya go.
- de
Añadir tu respuesta
Joshua Vande Walle estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 20,954
