Can't remove ignition key from ignition
1998 Honda Accord Ex 2.3 4 cyl. Ignition key stuck in the ignition will not turn all the way to last position to be removed, car starts no problem but only key available, and cant duplicate unless I remove it. Is there a pin stuck in the lock cylinder holding it in? I have tried moving the steering wheel, and transmission in the park or neutral position without any luck.
Es esta una buena pregunta?
5 comentarios
Thought I'd have a big bill if I took it to the dealer (new ignition switch, etc. etc.); sprayed oil into the lock, pulled the key out after a couple of wiggles. Thanks for the tip. I am positive you saved me a lot of money.
- de Gary Stevens
Well Thank you ssforest for the advice, I did exactly that you said, and worked, within 3 minutes I had that key out and lock cylinder working perfect.... Thank you for your advice seems that's the best fix for that problem.
- de Tedyot
im happy someone helped you with yours. i hope your car is running. wish this guy wld know bout chevy caveliers. lol good luck. mine makes a noise on left turns. cant find the answer im female and lost god bless i think accords r great cars
- de lynn
My '97 Accord EX (2.3) had the black key stuck in it for over a year. I had to keep putting a towel over the steering wheel to disguise the fact. I read about the WD40 trick (I had already tried pushing the 'T' bar firmly into 'Park', wiggling the steering wheel, wiggling the key...etc. Two small squirts of WD 40 directly into the key slot and the key came out second try. I didn't even have to yank on it. Try it - it worked for me. Thanks a million to whoever it was that first suggested this 'trick'.
- de Simon Edwards
Wd 40 work like a charm my key wouldn't turn all the way off and then when I did turn it all the way off it wouldn't turn back on so I pulled the key out and sprayed it with WD-40 let it set for two minutes hate works like a brand new car
- de chadgray2
