Pencil lead stuck in the reset port, how to disable it?
I was using a mechanical pencil to reset it, and now it resets when you give it a whack. How do I disassemble it and fix this problem?
Es esta una buena pregunta?
Use a very small drill bit with your fingers and drill out the graphite.
Fue útil esta respuesta?
Is the lead still in it? That was what I was trying to get you to remove.
Just looking back at this, the problem was there is about a 5 mm tall button inside of that you push down to reset the TI-84+CE, but there is some pencil lead stuck in the crevice next to it, I guess I need to take it apart. Thanks for the help!
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 2,701
