How to Set up D-Link DIR 600
I have purchased new router D-Link DIR600 and I have already inserted internet cable in to router port but I have done all setting but still ip configuration problem showing.
Es esta una buena pregunta?
When you plug your computer into the cable modems Ethernet port are you able to connect to the internet? If you can, your problem is the default gateway setting in your D-Link is not set to the cable modems IP address.
We use the term 'Bad Gateway' as the direction of the next hop is not known.
Think of it this way... You're on the shore of a large lake, looking out you can't see the other shoreline on the other side so you don't know if its there or not. But, if your friend got into a boat and went half way where he can see both you and the distant shoreline he could relay your signal. Thats the problem here.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 523
