Saltar al contenido principal
Guías de reparación y soporte para auriculares más pequeños que descansan sobre la oreja, también conocidos como auriculares supra aurales.
Preguntas 20 Ver todo
Why does my headphone keeps beeping very frequently?
I have Skullcandy Hesh 2 wireless headphones which keeps beeping in duration of every 5-7 min even when its battery is more than 50% . Please help
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 11
8 comentarios
Please Help my bluetooth headphones left side always makes a beep sound when playing something or whenever the headphone hears a sound played on it .it is very annoying please help..it does not fix it like the low battery etc
- de
got the skullcandy corded headphones and it would make those "grounded-like" noise :( what doi do with it?
- de
My bluetooth headphones keep saying “your device is connected” and beeping nonstop. The voice is every 2-3 minutes, the beeping is every 30 seconds
- de
Any luck? My skull candy hesh 2 r doing the same thing sooo annoyed
- de
I have blue tooth candie couture headphones, and they're beeping, even though I charged them all through the night, and won't stop even after I tried reconnecting them to my phone.
- de
Mostrar 3 comentarios más
Agregar un comentario
14 Respuestas
Respuesta Más Útil
Pair the device again. Both the device and the headset. Skullcandy headphones make this noise not just when the battery is low, but also when it becomes connected without pairing (like starting music on a nonprimary device that it had also been paired to).
In short, redo the bluetooth connection, that should fix the beeping
Fue útil esta respuesta?
Puntuación 7
4 comentarios:
This seemed to do the trick. I haven’t tested them fully to see if the problem persists. The issue is unpredictable, but so far it seems to hav stopped just from forgetting the device and re-connecting
- de
My issue was for the ink’d wireless 2 earbud though. So it seems like it’s a problem with several skullcandy headphones.
- de
Thank you so much! Worked for me
- de
Yeah! And what causes that, to beep?
- de
hi i also have the same problem before but thru research i learned to just holding the volume up or down to stop the beeping sounds. connect to it to your phone and then hold the volume up or down. just try it. works on me. ☺
Puntuación 7
12 comentarios:
This really works! I pressed and held the volume up button and it stopped beeping!! Thanks!!
- de
Thanks a lot! It works on mine too.
- de
It's not working on mine... ☹️
- de
It’s not working
- de
Mine too it wont work
- de
Mostrar 7 comentarios más
It does that to let you know your volume is too high.
Puntuación 2
3 comentarios:
To fix it just turn them down and it’ll stop.
- de
I muted it but it did not work
- de
Fixed my problem. I tried everything above turned it down one click no more beeping.
- de
I found a button pressed (i.e. stuck in and broken) and not returning due to spring failure beeps every 2 seconds. Manually pull button out.
Puntuación 1
As far as I know beeping is only for a low battery indicator.
Sounds like you have faulty headphones.
I would contact Skullcandy on repair or replacement.
https://www.skullcandy.com/customer-serv...
Puntuación 0
1 comentario:
I fixed it. For phones with Qualcomm processors switch off aptx codec mode to most stable connection mode in blutooth settings in phone.
- de
For me during conference call, Mute/Unmute/Mute your phone, and ++volume on headset. The beeps ended there.
Puntuación 0
1 comentario:
It didn’t work for me appreciate the info! My Iphone Had 5 got a 11 still beeps after call if I don’t answer it tried volume didn’t work ;(
- de
I have the same issue with Skull Candy… I suspect it’s our internal bloatware, it only seems to happen on my work machine. I think our firewall is blocking it, because after I get this it won’t connect again. Very frustrating.
Puntuación 0
One side of the ears want slides up like it used to do.
Puntuación 0
They are overheating give it a while
Puntuación 0
2 comentarios:
Feel the right part of the headphones and boom problem solved
- de
One of the volume buttons are stuck, pry it up without breaking and it should stop the beep.
- de
Beeping solved on iPhone bluetooth
Simple- turn off all haptics settings when listening to music. For some reason some haptics are triggered.
Puntuación 0
It may be , because of your settings.
My problem solved when I changed the settings.
  1. Go to settings.
  2. Then click Notifications
  3. There will be a list of apps which recently sent notifications. Found Android System among them and open it.
  4. Scroll down and look whether the option “ Apps are using mobile data “ is on.
That was my problem. After I turned it off everything became alright ?
Puntuación 0
Wash the bt circuit board with wd 40 or petrol and scrub with tooth brush gently wash it again with petrol and leave it for dry when it's dry reassemble headphones and enjoy ur own maintenance why bt headphone have beep sound because sometimes carbon can make buzzing humming sound I have done this process and it's really works
Puntuación 0
hii im also face this problem this website is helpful for me
there are 8 reason 1st technical issue wiring
i suggest you this website it will be helpful for you
Update (11/29/2022)
hii im also face this problem check this steps
low battery sign distance between the device and headphones technical problem in the headphone check this website
it will be helpful for your headphone im also clear this problem from this website
Puntuación 0
I have DOQAUS care 1 headphones and when I turn them on they keep making beeping sound and not letting me lower problem I have tried reseting it but it doesn't work
Puntuación 0
Añadir tu respuesta
Kartik Gupta estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 49
Ultimos 30 días: 242
Todo El Tiempo: 158,773
