Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Canon EOS Rebel T3 es una continuación de la línea de cámaras réflex digitales de Canon, la serie Rebel. También conocida como la EOS 1100D y la EOS Kiss X50, cuenta con un sensor de imagen de 12.2 MP y un procesador de imagen DIGIC 4.
LCD screen and backlight disassembly
I brought a new LCD screen without backlight on eBay for my Canon 1100d to replace the damaged screen on the camera.
Does anyone know if the backlight is suppose to come off the back of the LCD panel, it appears to be soldered in.
The backlight looks like a white plastic membrane and looks difficult to remove without damaging.
Thank you
Mark Bowles
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
In most cameras and smartphones the back light is integral to the display assembly, and if it's possible to separate them in order to replace one but not the other it would probably be classed as an expert repair.
That said, if you've got a broken LCD, you've nothing to loose by carefully trying to take it apart, in the process finding out how it fits together. With that knowledge you might be able to fit your old backlight to your new LCD. But if your old LCD is still just about serviceable you might not want to take the risk. On balance I'd be inclined to look at the eBay seller's returns policy, and if possible send it back and find another complete display from somewhere else.
Fue útil esta respuesta?
Puntuación 1
In your camera, the back light CAN be removed from the old screen and used on the new screen only replacement this video shows how. Sorry this is late (I'm new here) but if you still need the info or someone else does, this will do it.
Puntuación 1
Añadir tu respuesta
Mark Bowles estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 9
Ultimos 30 días: 34
Todo El Tiempo: 1,858
