Saltar al contenido principal
El iRobot Roomba 560 es un aspirador automático lanzado en 2009.
Preguntas 15 Ver todo
Roomba 560 Charging Problems
My Roomba 560 stopped charging. Instead the Clean button flashes orange every 2 seconds or so, with a clicking sound. After researching, I bought a new battery online and installed it. It then powered on fine but when I put it on the charging station, it flashed red stating "Charging Error 1." It then reverted to the orange flashing Clean button accompanied by the clicks. I checked and the battery is seated properly. It's also the same whether plugged in directly or in the charging station.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Try resetting the roomba’s software using the spot and dock buttons. Did you try plugging the roomba in directly via the charging port? Make sure that the charging contacts, home base contacts, and battery contacts are not dirty. If they are, use a clean, damp, and lint- free cloth to wipe them off. If that doesn't help, replace both the charger and the home base. If ALL of these fail, contact iRobot customer support as it is most likely a motherboard issue.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Roomba Warrior estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 613
