Saltar al contenido principal
El Nissan Navara es el nombre de las generaciones D22 y D40 de camionetas Nissan vendidas en Asia y Europa; y el nombre para todas las generaciones de vehículos en Australia. En Norte, Centro y Sudamérica se vende como Nissan Frontier.
Preguntas 20 Ver todo
Changed battery and I am having other control problems
I went to Advance Auto to replace the original battery on my 2011 Nissan Frontier SV 4 wd v6. They plugged in a box into the OBI 2 port. Changed the battery but the positive wasn't tight and when we went to check it pinged and wouldn't start. He took off the positive and retightened. The truck started, but the blower motor was on full and couldn't be controlled. The gauges do not initially work well but after a few seconds they work. Also some small things didn't work, open door alarm, ect. They then changed the fusible link on the positive cable, no change. If you use the power pack on the OBD2 port everything works fine. Remove it and the problems show. What could be the problem? - fuse somewhere to OBD2 port? Looked at all 3 fuse box locations and they seemed fine.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
It was a fuse that controlled the OBD2 port - all fixed
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Where or what was it called in the fuse box
- de
I have this same issue after changing my battery. How was this fixed? Where was the OBD fuse?
Puntuación 0
Añadir tu respuesta
Vince estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 1,234
