Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Esta cámara pertenece a la serie de cámaras HX de Sony. La reparación de este dispositivo es similar a la de las otras cámaras de la serie HX y requiere destornilladores y herramientas de palanca.
How to change the battery broken door
How to change my broken battery door on my Sony Cyber-shot DSC-HX400?
Rgds
M. Picard
Update (11/25/2017)
Imagen
Here is the good way to remove it but I don't know how to remove the grip handle.
Es esta una buena pregunta?
Puntuación 1
1 comentario
No I dont. Can you help me?!
- de
Agregar un comentario
5 Respuestas
Solución Elegida
I received the battery cover today and replace the door part easily.
Imagen
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
This picture taken from one of the repair guides seems to indicate that if you take the back off you can probably slide out the hinge pin. But note carefully how the spring is located so that it operates correctly after reassembly. (This guides are marked "Difficult", but really aren't.)
Imagen
Puntuación 1
2 comentarios:
Hello Thanks for your answer but the hinge pin must be removed from the other side, under the grip handle. Do you know how to remove the grip handle?
- de
- de
The battery door is in 2 parts, the hinge part and the door itself, get a flat blade and gently prise the door part from the hinge section it will slide off easy and then just click in your new part, easy peasy.
Garry
Puntuación 1
You can do it even easier! The hinge part has a little rectangle hole at the end of the hinge part! Put your nail underneath and you flip the door part easily from it!
Puntuación 1
1 comentario:
there's 2 holes see can you send pictures of the hole that you're talking about?
- de
I've made a little hole just in front oh the pin in the grip hand. I pushed the pin. I removed the broken door and I did the reverse to put the new one. I plugged the hole with rubson. Around 15 mn to do that.
Puntuación 0
Añadir tu respuesta
Andreï Picardowski estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 47
Todo El Tiempo: 2,687
